Reducing weight is always good and can help since you will have a better power to weight ratio.
To attach your pieces I think most people tape them down to start. Then once testing is finished they add mounting points on the back like using metal strapping and screwing the ends into the plastic shroud around the tires or use one of the mounting points for the shroud.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
