Old 05-05-2010, 11:43 AM   #1 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Cheap carbon fiber hoods are almost as heavy as stock
Any time I remove components from the Insight, I weigh them. The stock hood, which is aluminium, weighs 9kg/20lbs. Being curious about the potential for weight savings with a composite hood, I looked up how much a riceboy carbon fiber hood weighs. Your run of the mill $600 CF hood for a Civic weighs 18lbs. So you probably save 6lbs versus aluminium. That's pretty unimpressive for $600. I'm sure the savings are even less for replacing plastic panels with carbon fiber.
However, I might be able to make my own carbon fiber hood for around $100 in materials. A hood-sized sheet of fiberglass cloth weighs 1lb per layer, and CF is lighter. Of course you'd have to add resin, and bolt on "features" like hinges, latch, and washer nozzles, but I couldn't picture it coming in over 7lbs.
