Old 05-06-2010, 11:37 AM   #154 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by Old Tele man View Post
...the Gross Vechicle Weight Rating (GVWR) on the door sticker of my '09 Vibe is 3860 lbs, so I did a little 'number crunching' to see how close the other numbers related to that value:
1) door sticker tire pressure = 32 psi, front and rear
2) tire sidewall "maximum" air pressure = 44 psi
3) tire 'load index' value = 89, which equates to 1279 lbs at maximum air pressure
4) so: (32psi / 44 psi)*(1279lbs / tire)*(4 tires) = 3720 lbs
5) that's 96% of GVWR, ie: (3720lbs / 3860 lbs) = 0.96
6) looks "close enuf" for decent approximation!
A couple of comments:
For item #4: The "rated pressure" is 35 psi, not 44 - and the load is NOT proportional to the inflation pressure.
The actual load carrying capacity of a P205/55R16 89H at 32 psi is 1157# (for a grand total of 4628#) or the tires at GVW (assuming all 4 tires carry the same load when the vehicle is fully loaded!) is 83% of the GVW.
The way it was calculated in the quote should be raised some questions as the estimated load carrying capacity of the tires would be LESS than the GVW.
