I'm all for running tire pressures above manufacturer recommendations. I'm decidedly not in favor of running them so high that safety -- for the occupants as well as those who might encounter them on the road -- is thrown out the window. I refer to the extreme pressures - 60psi and the like - run by some folks in search of MPG improvement. There's a sensible compromise between that and manufacturer recommendations.
Originally Posted by Christ
I run Gerald (1/2 ton F150) with 50-60PSI [...] the fronts do the majority of the braking anyway. I would lose little or nearly none of my braking power (unloaded) by losing traction in the rear of the truck while braking, [...]
(Tire pressure quoted for next comment.) That all assumes that you are stopping in a straight line on a smooth road. That is not often the case in normal situations, let alone emergencies.
Originally Posted by orange4boy
More interesting tire info. Especially if you want to drive on the Autobahn.
Note that the recommendations top out at 7.5psi above manufacturer recommendations. That's going to be in the 38-44psi range for most vehicles. A long way from 60psi.
