Originally Posted by dgibso26
This vehicle has a 72v, shunt motor, 400AMP, motor has 7.0 horsepowers. We was wondering if we have to design the controller that on works for a shunt motor or can we design a controller that works for a shunt or series motor.
Series and shunt motor controllers in theory are interchangable.
To drive a shunt motor off a series wound motor controller you would only attach the controller to the motor armature and the batteries would attach directly to the motor field through a contactor, this would obviously cause some limitations but would work although speed/rpm and power selection would be very limited.
Also much of your design work has already been done on the open revolt controller (paul and sabrina have a thread on it) If you really want to plagurize
Or you could look at their design and refine and modify it for your purposes then present it back here when done of coarse
