Old 05-07-2010, 12:31 AM   #9 (permalink)
autoteach
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
Get rid of restrictions. Duramax saw 1-3mpg improvement and power gain with .5inch increase in diameter and straight through design. The benefit on a turbo motor, diesel or gas, is that the pressure past the turbo is lower than stock. This larger difference between the two sides of the turbine cause a greater speed of rotation, which equals more boost, more power, and greater efficiency (look up boost pressure and compression efficiency graphs). I would suggest it.
