Old 05-07-2010, 10:58 PM   #5 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by ExplodingDinosaurs View Post
For my sepex motor, 72 V continuous on the field would burn it out, so be careful about putting that much voltage directly on the field.
Lee Hart (EV god) was a sepex is often designed to run the field at about 1/3 of the armature voltage.
Hmm, sounds like you are running a 24v sepex at 72v, most sepex come out of forks and most antique sepex do indeed run straight off the pack voltage, of coarse if you up the ante it will not like more for long.
Of coarse modern sepex use PWM on both field and armature so you can similate different torque and rpm levels.
