05-08-2010, 05:31 PM
#9 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Originally Posted by ExplodingDinosaurs
Great thread. Here are a few ideas for things an EV can do better:
- Instantaneous traction control -- an electric motor can react far faster than exploding dinosaurs in a gas motor
- Less time lost to shifting
- You are always in the "right" gear (you want to rev the electric motor high for efficiency, so no time lost for downshifting)
- Robot recharge -- drive over a power connector so you don't even have to plug in, or a small robot finds a plug and plugs you in
- Falling torque curve in constant power mode gives an inherent form of traction control -- as the motor speeds up torque drops
- Quieter means more feedback to the driver for hard cornering or hard launches in racing
- Redundancy for reliability is easier to do -- you could do 8 motors, 8 controller, and 8 separate battery packs
- Smaller size of the EV motor allows for more packaging options, such as behind the rear axle or putting it into the driveshaft tunnel
- You can work on the car right after a drive without burning yourself, and if you burn yourself that's a diagnostic something is wrong!
- Things are less likely to vibrate loose, as the electric motor is smoother
Very well thought out!
