Originally Posted by hondaworkshop
So could you say as long as I'm staying in closed loop its the same or even better to accelerate at normal brisk pace from a stoplight instead of an agonizing crawl? That would sure make alot of folks behind me less annoyed.
It can't be worse for sure. But give it a try, it's really easy to test. It can be as short as a 1 mile test. Start at a stop, pick a target cruising speed at which you'll stop accelerating, reset your trip on the SG and do runs accelerating like a granny and runs giving it a lot of pedal.
I usually set my target at 40 mph in the city. I go 1-2-3-5 shifting a bit over 3k rpm.
