Old 05-09-2010, 11:07 AM   #2 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Even if there aren't a lot of aeromodded Camries on this site or elsewhere, most of the mods done here will apply to your car. The only mods specific to sedans are trailing end aeromods, like an extended Kammback, or adjustments to your spoiler.
I think you'll find the grille block provides the biggest bang for the buck. I would also move the rear wheel skirts up the list. They shouldn't be too hard to do.
If you have fairings behind your tires and a smooth underbody, you probaby won't need the air dam and side skirts. If the underside of the car is smooth and orderly, there's not too much need to reduce airflow under the car.
I'm glad to see a madman here. Welcome.
