F-250 Dually Diesel - Considering Electric add on
Hey guys,
At my disposal now I have a 2003 F-250 Dually, diesel. In the coming months I will be working on it slowly to bring it back to its mechanical greatness and eventually put it back on the road to see what kind of numbers one can dial out of this type of truck.
Regardless today I was considering the following;
What if I added an electric motor to help drive the rear wheels once the truck was moving or possibly to get it into a roll.
The how is what I want to ask about ... Fabrication aside, would it be possible to attach a transfer case to the drive shaft closest to the rear axle and attach an electric motor to the transfer case?
Its the same prinicipal as a 4wd to the front, my only concerns are about the gearing inside the transfer case and how to engage the electric motor once the vehicle is rolling etc ... Also, I am not sure how many neutral drops the automatic transmission can handle before I have to scrap it and switch to a manual ..lol
Has this approach ever been taken?
Thanks ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
