Old 05-09-2010, 08:49 PM   #26 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Ah.
The ECU decides when it's time for lean burn mode. My engine can only do it under very light loads, and it won't do it until it thinks the catalyst is hot. But if conditions are right, it will automatically go in to lean burn, and stay there until I ask for more power than it can provide while lean burning.
Unless you have a Civic VX, HX, 02-05 Civic Hybrid, or MT Insight, you don't have a lean burn Honda. AFAIK, the folks on this forum who have converted their cars to lean burn have installed an engine and ECU from one of those cars. Lean burn models use different heads, pistons, ECUs, and emissions systems.
