05-09-2010, 11:01 PM
#25 (permalink)
speed density
Originally Posted by AeroModder
The car they used had a MAF (Mass air flow) sensor and a turbo. My car has a MAP (Manifold absolute pressure) sensor and is naturally aspirated. Results vary.
speed density systems or
systems with Manifold Absolute Pressure MAP sensors
might actually get slightly IMPROVED FE with a clogged or restricted air filter as
MAP = Baro minus intake vacuum ,
and a restricted air filter will INCREASE intake vacuum and DECREASE the MAP value . and since MAP is the primary load sensor
AND
an increase in intake vacuum will DECREASE fuel pressure
all else the same less MAP = Less fuel injected
of course Mr 02 sensor will correct the mixture to 14.7 to 1
but
the ignition timing map will now measure with slightly less load
and too many variables to predict .
bottom line -
a clogged or restricted flow air filter WILL NOT DECREASE FE in a speed density system
