Write down the Engine Size, Speed, Tank Size, Offset, Cutoff for your neon.
Then set those items for the Rio. If you don't know about certain ones (eg speed), just set them to zero or default. Do a fillup procedure to clear any data from the other car. I would record these settings for a future date, as well.
When you get back, do the opposite to set it back to yours. Keep the same offset until the 2nd fill, since the first one will be a partial tank.
