Old 05-12-2010, 06:19 AM   #6 (permalink)
sarguy01
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Originally Posted by datsundude91 View Post
I believe so. The choke pull off diaphram needs replaced. The warm idle speed seems a little high, and I am not sure about the mixture.....but other than that It seems to run great.
A high idle will cause decreased fuel economy. Higher RPM's = more gas.
An air/fuel gauge can help you set the mixture properly. Narrowbands re cheap but are not as accurate as widebands. A wideband will cost you at least 160$ used on Ebay.
Also, can you set the timing? I am assuming you can, is it set correctly?
