That would be about the same as a graduated filler neck or fuel dipstick, right? We've used that at the AMEC events: fill until the fuel is level with the flap in the filler neck.
You still have issues with fuel aeration, and you'd have to make sure the car is level. Parking at the same pump each time should be required.
