Originally Posted by bennelson
Also, I talked with one of my electronics buddies last night. He said that to protect my circuit board, I could even just cover it with the same protective varnish that I used on my motor windings! Just mask off the LEDs and anything else I would want to see and blast away!
Ben,
Before you do this, Take the board, and pop it in the toaster over at about 100-135 degrees F for about an hour. This will take all the moisture out of the fiberglass board and make sure it is DRY!. then coat it and I bet you will never have a problem again.
-Adam
