Old 05-12-2010, 06:13 PM   #145 (permalink)
moTthediesel
Turbo Lurker
moTthediesel's Avatar
VonBondo - '65 Porsche 356SC Coupe
The trick with a dipstick is it only tests the level *after* the fuel is there, and if it is too high, then what? It would be better to "see" the level as the fuel is topped off, I think.
Yeah that was my thought as well. The funnel I use now reaches all the way into the tank, and I use it like a dipstick. But once you overfill it, there's nothing you can do. With a float gauge you could slowly inch it up to the mark. Some kind of a float switch could work, but I'd be a little leery of using anything with an electric circuit inside a gas tank
