Old 05-12-2010, 06:33 PM   #13 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
4' would be a fairly long crease with hot glue, even with two hot guns to start with. For a crease across the grain, I don't cut all the way through - I just use a blunt tool with maybe a 1/8" end diameter (3mm) to make a crease that the material will follow easily. Such a groove makes a good guide for the tip of a glue gun or a small, just-lit torch flame. Hot glue or silicon can be added after the initial folding, too. The creases don't need to be straight, either.
