Old 05-12-2010, 09:12 PM   #10 (permalink)
ShadeTreeMech
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
You might also look at the 3.3L QSB common rail Cummins. It gets excellect economy but has roughly the same power as the 3.9L 4BT and is a bit lighter.
The 5 cyl mercedes found in Dodge Sprinters are excellect, from what I've heard and are economical, plus they rev a lot higher (about 5k rpm IIRC)
the 4BT has been around forever, and it is a 6BT (5.9 L) minus 2 cylinders, so there is a lot of parts that swap plus the 4bt, being around forver, has myriad available parts and support, and is easier to find trans that fit it easily. While the 6bt is a great engine, so is the 4bt, yet it has the ability to get better economy.
I'd definitely recommend you go the Cummins forum. Lots of good info and many of the folks are really into economy.
Living in Cali as you do, you need to talk to a CARB ref ASAP before your dreams are smashed.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
