Old 05-13-2010, 08:48 AM   #79 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
As long as you do a few runs each of before and after coastdown testing, then you are a scientist and I will listen. Otherwise, you're just a guy building a Chia car and shouting about random fluctuations in your fuel log.
Vortex Generators have been covered at length in other threads, and they can be used effectively on the trailing edge of round objects, but that's it. Elsewhere, they just increase drag and frontal area. But again, if you don't believe the other scientists here, run your own trials.
Here's a case where a car's underside was originally covered in vortex generators. Covering them up reduced aerodynamic drag 10%:
http://ecomodder.com/forum/showthrea...ges-13199.html
The Following 2 Users Say Thank You to RobertSmalls For This Useful Post:
Frank Lee (05-13-2010), PaleMelanesian (05-13-2010)
