somethin strange is happening with my arduino.
i calibrated vss pulses, so no problem there
connected injector and at start it worked fine, but now i cannot calibrate it. today it showed almost the same numbers as my stock instant consumption gauge in car. problem is the readings are ''jumping'' around. it shows ~7 l/100km then jumps to 32 l/100km for a second and returns to ~7 and that happens without touching accelerator pedal.. then again without changing anything mpguino shows instant consumption around ~250 l/100km under same conditions.
also, how to delete mpguino memory. even if i upload program ''Blink" from examples and then again mpguino code, setings stay the same.
thanks!
