Old 05-17-2010, 01:11 AM   #1 (permalink)
carbonaltima
30.67 MPG
carbonaltima's Avatar
Adding an electric motor to a gas powered vehicle
I've had an idea for a while now that I'm still working out. On a front wheel drive vehicle we could add an electric motor to drive the rear wheels. It could be mounted in the trunk and use a chain through a cut in the floor that would either connect to the sprocket on a modified axle or on the inside of the tire itself. We could use a fork lift motor. It would be sufficient for city driving.
Has anyone tried this. Did anyone use a different method for an ev hybrid project vehicle?
30 MPG is the FE equivalent of a 13 second 1/4 mile.
