Originally Posted by cfg83
Christ -
Hee hee. I would have tapped the brakes at the very end so that he knew his argument was moot before he walked up beside my car.
CarloSW2
See, I don't ever really think about this - I've never been rear ended doing this, in probably 4-5 years of doing it as often as possible (I hate changing brakes, is all), so I figure that everyone can tell I'm slowing down/stopping, and after awhile, I forgot to hold the brake pedal just past the switch point anymore. Now, I do this instinctively without ever touching the brake pedal.
I just turn the engine off, and start walking the transmission down through the gears. If I come up a little long on the engine braking distance, THAT'S when I use my brakes. It doesn't happen often, because I normally don't need to come to a complete stop anywhere. When the light turns green, I turn the key back on, and begin re-accelerating back to the speed limit. I try to time the lights, but around here, it's killer at times, especially during peak-traffic times.
I guess if this is going to keep happening, I'm going to have to start using the brake pedal a little bit again... that's a shame, though - more electrical load.
