Old 05-17-2010, 11:15 AM   #11 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by wyatt View Post
How did you install your fan light? Is it just an LED and some wiring, or did you put a resistor in line? A wiring diagram would be helpful for those of us not too electrically inclined. Thanks.
It's a "ghetto" temporary install. Just a small bulb on the floor. I hooked it up to the fan relay.
The best/easiest way to do it would be to get a second set of radiator fan plugs from a junk car and make a short harness that would plug in between the car's wiring harness and the fan. You can then splice into the short harness for the fan light without cutting up any of your car's wiring. Or you can just splice directly into the fan wires. Use waterproof connectors to avoid corrosion. You really only need to run one wire from the fan to the light if you figure out which one is switched. But it's a lot easier to just run two wires from both fan wires to your light. Almost any wire will do. Something already paired together would be nice. Speaker wire or an old extension/power cord is fine. Just route it so that it won't get caught in any moving parts or pinched, cut, etc. Use cable ties or electrical tape to keep the wires from moving around. And when you route the wire through the firewall, make sure you protect the wire from the sharp metal edges of the firewall. You might get lucky and be able to squeeze the wires into an existing wiring grommet. If not, drill a hole after carefully checking both sides of the firewall for any important parts you don't want to drill holes into. Then install a rubber grommet to protect your wires.
A small 12 volt bulb like what's used in dash lights or parking lights will work. But be careful where you put it, they can get hot and melt plastic or carpet if they're touching it. Or you can use an LED. Most LEDs are not designed for 12 volt use, so they will need a resistor. I think something like 330 ohms or slightly higher will work. Or you can look for an LED that's prewired for 12 volt use.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
wyatt (05-17-2010)
