Old 05-17-2010, 01:20 PM   #5 (permalink)
AeroModder
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I noticed that having the driver's side front window open causes that side of my kammback to shake. That CFD model shows why. It's not allowing the air to roll onto the roof and over it.
Having the rear windows open doesn't seem to have any effect. Unfortunately, only the passenger side one works. I'll probably check the wiring on it later and make sure it's connected properly. If not, a new motor might be in order, since I removed the AC and summer is coming.
If you tuft test it again, try it with the window down a crack.
In Reason we Trust
