Old 05-17-2010, 07:14 PM   #1 (permalink)
Winfield1990
RWD rear motor , regen braking
Is it legal to have in the REAR ONLY REGEN BRAKING.. While in the front still disc brakes.... Since depending on the weight distribution my design would have the rear brakes might not the be biggest impact on my stopping power since the weight shifts forward.
Also could regen braking be used with the brake pedal in conjunction with the front disc brakes EITHER , slight braking use regen while harder braking uses both...
Or braking period uses both...
