Cost no object? Go for A123 cells (good luck getting them) They support high discharge and weigh less than lead. Energy is also higher so good for range.
For 13 seconds of discharge you are in the realm of ultracaps. Siemens S+M components used to make them (maybe they do again) also company called Maxwell make some large value caps that support high discharge rates.
