Originally Posted by Rokeby
And then again, maybe not. ![Embarrassment](/forum/images/smilies/redface.gif)
Well, to tell the complete truth, I've given thought to putting Great Stuff expanding insulation foam on the nose, then sculpting it to shape, and/or using smooth plexiglass as a curved form to hold the foam in place until it sets up, just like using plywood forms to pour a concrete building foundation.
Best method is probably to glue foam blocks onto the naked (stock nose cover off) front of the car, and sculpt that to shape as a male master for a female mold. On homebuilt airplanes, most guys use this foam glued to engine method to make engine cowlings. Gasoline fumes will destroy the foam, leaving little powdery residue.
