Old 05-20-2010, 09:29 AM   #10 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I'm not sure if power windows or locks were ever offered. I've never seen them on a Metro. Some 1989-1994 Suzuki Swift GTs had them, but the parts won't fit the newer Metros. All of the following applies to the "new" 1995-2001 cars. If you want MPFI, you'll have to get a Metro/Swift with the 4-cyl engine from 1998 or newer. If you want maximum fuel economy and OBDII, get a 1996+ 3-cyl Metro hatchback. There are very few options on these cars. Some had ABS. Some had a tachometer. Some had trip odometers. Metro hatchbacks were sold with both 3 & 4-cyl engines. Sedans were 4-cyl only. 3-cyl 5-spd had a 4.39 final drive, 4-cyl 5-spd had a 3.79 final drive. Automatic was only an option on the 4-cyl, avoid it. Power steering was an option on the 4-cyl sedan. Some of the '95-'97 Metros had recessed sealed beam headlights. Swifts were all 4-cylinder hatchbacks.
The "new" cars have another rust problem not found on the older models. The front section of the rear wheelwells rot out.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Chris D. (05-23-2010)
