I think the speed limitation comes from the centripetal forces at the high rpms. You're dealing with something a fair amount larger in diameter than a turbocharger's turbine. The velocity at that larger diameter is going to be quite a bit higher despite the lower rpms. Plus, its not just one solid piece of aluminum spinning. Thats my guess at least.
