Originally Posted by swede
The coroplast really doesn't like the heat and tends to sag and buckle when the temps hit the 30 C range. Any lightweight alternatives out there that you can think of?? (I'm not good at all with fiber and resin so that is out)
Bajascoob used 4 mil plastic sheeting for his. It shouldn't flap around too bad. Or it could be the black heating up in the sun, so white coroplast might not sag as bad.
