Thanks Darrell! I have to thank you again for the testing we did using your Scangauge on relative values of cruise control vs engine-on neutral coasting versus DWL. I started using the so-called "hang-time" technique as much as possible and it seems to be working. I do need to start working on a bellypan.
best weishes, L&S
