Old 05-23-2010, 05:29 PM   #2 (permalink)
some_other_dave
Unfortunately, heat does not transfer that well from metal to air, so you wind up needing lots of fins to make surface area for the transfer. Air also tends to have a real mind of its own on where it wants to go, whereas water can be pumped just about anywhere you want it to go.
As a result, air cooling tends to be more bulky and the engine pumping losses seem to be similar to, if not slightly more than, those for a water pump.
-soD
