From Wiki: ""On the third pass, it collided with the surveillance aircraft. The J-8 broke into two pieces, while the EP-3's radome detached completely and its No. 1 (outer left) propeller was severely damaged. Airspeed and altitude data were lost, the aircraft depressurized, and an antenna became wrapped around the tailplane. The J-8's tail fin struck the EP-3's left aileron forcing it fully upright, and causing the U.S. plane to roll to the left at 3-4 times its normal maximum rate.[6]
Area of the collision in the South China Sea
The impact sent the EP-3 into a 30° dive at a bank angle of 130°, almost inverted. It dropped 8,000 feet (2,400 m) in 30 seconds, and fell another 6,000 feet (1,800 m) before the pilot, Lt. Shane Osborn, got the EP-3's wings level and the nose up.""
