Old 05-24-2010, 11:45 AM   #110 (permalink)
janvos39
janvos39's Avatar
jvsgears - '14 Skoda Octavia
Team m8
90 day: 52.47 mpg (US)
Hi Redyaris.
I had a problem with the overruning gear in the gearbox. It didnot bloc anymore in one direction so I had to repair. I use only high gear at the moment.
Besides that I was also quite busy with making a special gearbox for a Toyota yaris for ralleye cross.
Indeed Craig has made a jump in his best MPG with the new gears.
The small carburettor is not yet tested. I am preparing a logging system that will log a number of functions of the Burgman during driving. On the carburetter I will place a potentio meter so I can read in the logfile the opening of the throttle.
Also position of the variable cam will be monitored and other obvious functions like revs speed temp of water
The Following User Says Thank You to janvos39 For This Useful Post:
PeterS (08-07-2011)
