Old 05-24-2010, 02:15 PM   #3 (permalink)
Grant-53
Start with a good tune-up if you haven't done it already. Check your engine compression when you replace spark plugs and check the timing belt. Air dam and radiator duct work, along with rear wheel skirts would reduce drag. A target of 50 mpg is good for the next step! Enjoy!
