Originally Posted by Arragonis
- As mentioned better heat transfer from using water vs air
I think there is something to it being possible to tweak a bit more efficiency out of an optimally air cooled engine, but not with the bolt on fan.
The "as mentioned" bit is whack, because you still have a metal to air interface with water cooled, only now it is at the radiator.
and yah, there are conveniences with water, that isn't the point
