Old 05-25-2010, 09:44 PM   #6 (permalink)
EVDRVR
I would highly recommend getting a Scan Gauge II and a log book. Then use those two together to try moding the throttle pedal actuator.
I know it isn't tinkering much with the vehicle but your already doing so well that I'm sure a SGII and a notebook will get you a new baseline to work from. That 97 isn't going to have many instruments in it so the SGII is going to be an amazing add on.
Almost everything that you do technique wise will increase the range of that EV when you get it or a more commuter friendly vehicle if you don't need the carrying capacity of a pick-up..
Not a pick-up aero expert but I think the bed cover is pretty low hanging fruit.
Welcome.
