Depending on how much boost you plan to run, either the 302/351 injectors, or the Ford Racing 24lb injectors would be good. The 24lb ones would most likely need some ECU tuning, however, as I don't know if it can adjust the pulsewidth enough for those to work otherwise. With big enough injectors and tuning, you could probably run 8psi or so without an intercooler on 93 octane. If you add an intercooler, you might be able to push 10-11. I'm not sure what the limits of the engine are, however, without internal mods.
It would definitely perk the truck up a bit, and unless you get too heavy on the gas, it probably won't hurt MPG much. Of course, when you get it loaded and make it work, you can laugh at the V8 guys as you cruise right past them, and still get better mpg overall.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
