Old 05-27-2010, 01:11 PM   #10 (permalink)
Otto
Originally Posted by 3-Wheeler View Post
Yes.
.....Saran Wrap.....
Only precaution is to use minimal amount over the foam, otherwise it will not setup properly.
The expanding foam needs contact with the air to cure, and wrapping it tightly with any kind of wrap will prevent air contact with the foam.
Jim.
Thanks, Jim, I've wondered about that, or Reynolds Wrap, etc..
Using such, I could wrap the stock nose/bumper cover on the car, spray urethane foam on it, and the foam would conform to the nose shape but not stick due to the Saran Wrap acting as a prophylactic. The foam over the Saran Wrap could expand and cure properly. Once cured, it could be carved, sanded, or sculpted to shape. Then, the carved foam piece could be lifted off the nose without sticking.
Since it is d
