Old 05-28-2010, 08:46 AM   #14 (permalink)
user removed
Originally Posted by AeroModder View Post
I'll need to look at that now. I'm wondering about the kickdown rod, though, and if pulling that off can help it not force downshifts when I don't want it to.
Can you adjust the kick down rod to bring on up shifts earlier?
Pull rod=lengthen
Push rod=shorten
ATs that have kick down cables, rods, or vacuum servos, in most cases will shift very early if those components are not adjusted properly. At least it was that way some years ago.
regards
Mech
