Old 05-28-2010, 01:58 PM   #10 (permalink)
stevegaarder
Originally Posted by MPaulHolmes View Post
Oh, I finished a control board for a synchronous rectification controller, which can be modified (by changing software only) to control 2 separate coils.
Let me see if I have this right: a synchronous rectification controller uses MOSFETs instead of the commutating diodes, and so the controller board has a second output to control those MOSFETs. What I could do is use this controller board with two diode-based power boards, one for the armature and one for the field, and rework the software to handle this. Is this correct?
thanks,
Steve Gaarder
