Old 05-28-2010, 01:39 PM   #1 (permalink)
nubbzcummins
The Odyssey Van - '11 Honda Odyssey EX-L
90 day: 29.1 mpg (US)
silver racecar - '13 hyundai accent GS
90 day: 38.8 mpg (US)
Dodge turbo diesel programmer/FE tuning questions?
I have a Smarty S06 POD programmer with REVO for my truck. It has tunes in it ranging from half stock power to +170whp over stock plus ability to run 1-100% of any tunes power. It also has the ability to adjust timing, fuel rail pressure, torque management, wastegate on/off, tire size adjustment, and 25-250mph adjustable speed limiter. Should lowering the power output causing it to be under more load be more fuel efficient? Testing now running +30whp tune and 25% power output. So far have noticed higher load on motor, no smoke, slower boost climb, and less overall boost. Will see how this helps/hurts mpg but curious on what in theory it should do.
The Following User Says Thank You to nubbzcummins For This Useful Post:
elhigh (05-28-2010)
