Originally Posted by Nevyn
I'd say that it looks very nice. My brain is trying to ask "What about the coroplast having sharp corners and cutting the fabric? What if the fabric tears?" and I'm trying to shut it up.
Haha, it's all good; nylon is pretty tough stuff but one suggestion I have is to get nylon lycra or some other "four-way stretch" fabric, otherwise you can't cover the top and bottom too.
Originally Posted by Tom O
It looks good!
If you like it enough to make it permanent, you could always cover the fabric with fiberglass resin and make it a lot harder and not worry about the fabric tearing.
Hmmm, I might do the front around the corrugated plastic piece, but I like the idea that I can take it off the grill if I ever want to for some reason.
Originally Posted by EVDRVR
Did you give any thought to using vinyl? Just make yourself a aero "bra" that covers the grill opening instead of leaving it open as the commercial ones do. It would be more durable than fabric and the surface could be wiped off. I'm afraid any open weave fabric would get pretty stinky after a few hundred bugs smash into it.
I thought about using a lot of different stuff, including vinyl and
monokote plastic wrap, but in the end the lyrca was cheap ($30 for a 4x8' sheet), easy to cut up and not permanent. Plus, I'm not very good when it comes to making aesthetically pleasing exterior stuff, so I went with something lazy
Not to mention, this stuff's lightweight, and I can always wash it if it gets to smelling.
