Old 05-31-2010, 09:04 AM   #28 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
unfortunately climbing a hill is one of those activities that should put you closer to bsfc peak for a typical vehicle (allowing you to store energy in altitude for a nice glide later while running near peak efficiency). I think the only solution (short of a manual swap) is to override gear selection and lockup so you can climb in the highest gear that works without spinning the converter.
its called ecoMODDER for a reason
