Old 05-31-2010, 11:36 PM   #6 (permalink)
Thymeclock
Originally Posted by CapriRacer View Post
Differences between tires are going to have much more of an affect than tire size will - so choose carefully. Just be aware that there is a technology triangle between rolling resistance, treadwear, and traction (especially wet traction).
Good advice.
I don't think it will affect your fuel economy much, if at all. Why not stick with the size originally specified for the vehicle? At least that way your speedometer and odometer will read correctly.
Personally, what I look for in a tire is the best wet traction available and good tread wear. On dry pavement even bald tires will work. On wet pavement it's a whole 'nother ball game, as it may save you from being involved in a crash. To me having the optimal advantage in bad weather is worth more than the few cents saved in fuel.
"Always buy the best. You'll never be disappointed."
