Old 06-01-2010, 11:11 AM   #6 (permalink)
Hondo
faster Fiero
On the road again
Well, it works as good as before. Now time will tell, it worked great driving to work this morning. I did install a switch to disconnect the precharge resistor while charging. I also used a small 12v garden tractor battery to run the controller that is TOTALLY isolated from vehicle ground. I am getting some "stray" voltage from the acid mist like Ben was getting on his Metro and I wanted to make sure none of it got to the controller. I will keep you all posted.
