I'm posting here since this is the freshest of the many threads with similar title.
This morning I found this local article,
Opona wymyślana na nowo. The
Google translation appears to have a problem with formatting (the ads on the right cover part of the text), so here's what it's about
Michelin sponsored a tire conference in Rio and among the new trends is a very small diameter tire - 175/70R10. Using a 10 inch wheel shaved 40kg (88lbs), which should help fuel economy. Here's the translation:
The first one is a very small, 10-inch tire and wheel (175/70 R10), which provides the same performance (traction, braking ability) as a 14-inch tire (175/65 R14). Thanks to miniaturization, the total vehicle weight was reduced by almost 40 kg, which translates into reduced fuel consumption and reduce carbon dioxide emissions.
And that's it. No word about lower rpms, gearing, etc. They didn't mention that the savings from switching to ATV tires would only be in stop and go traffic.
What matters is
where you're going, not
how fast.
