Old 06-02-2010, 08:16 AM   #173 (permalink)
bondo
bondo's Avatar
Much better result Fubeca!
Sorry I missed seeing your post on the improvement in you percentage of fuel efficiency. That is alot better. AC does have a tremendous drain on your gas usage. I try not to run mine that often, but in the high heat and humidity of Arkansas, it is a necessity at times.
Hope you can post some even better results now that you thread is back active.
Thanks,
Bondo
Maybe the 7% increase can be reported instead of 4% in the third line of the top forum picks on the ecomodder home page.
